Thread Tools
Old 27-10-2016   #1
Netherlands
Ypsilon 1.4 12v
Hello to all
i was already a newbe with my x1/9
But i want to buy a Lancia ypsilon 1.4 lx with a 1.4 12 v engine
Pratola Serra engine
with a lot off km/miles
anyone now if these engine are good en easy to maintane???
Greetings from Holland
rita is offline Reply With Quote Quote
Old 27-10-2016   #2
varesecrazy has donated!
Quote Originally Posted by rita View Post
Hello to all
Hi Rita. Say hi in the bravo.brava section..most common use of that generation of engine. @Adrian Bravo
Charlie
Old 27-10-2016   #3
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Re: Ypsilon 1.4 12v
The 1.4 12v engine (found in the Bravo, Brava, and Marea) were not economical. Fuel consumption was as bad as a 2 litre engine, and the cam sometimes needs replacing as they wear from poor maintenance.
To be honest, i would avoid this engine.
Current Garage
Mine: 2013 VW Passat Sport BlueMotion Tech 2.0 TDI Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 27-10-2016   #4
bluejohn125 has donated!
Re: Ypsilon 1.4 12v
OK the engine was not great, but if this one is running OK without a noisy / tapping top-end then it should not be automatically avoided if an interesting older car can be kept in use. If there are problems then yes... replacement parts are difficult to find and you don't want to waste money.
The engine was a good idea in theory, adding a modernised cylinder head to the old Tipo-type 1.4 SOHC engine, but in practice it was disappointing (but not disastrous). Fiat did the same thing with the Tipo / Tempra 1.6, giving it the 16V 'torque' head for the Brava / Bravo / Marea, and this version was successful right through the Multipla and Stilo models.
bluejohn125 is offline Reply With Quote Quote
Old 27-10-2016   #5
Re: Ypsilon 1.4 12v
With these engines the oil supply is the most critical, the pipes feeding the camshaft can become clogged with 'gunk', and so you must flush the oil properly to clean blockages, and use a high quality oil. If the camshaft becomes worn or damaged you hear a loud tapping from the top of the engine, this can disappear if the blockages are cured and the camshaft will still work even if there has been some wearing to the lobes.
I like Valvoline Max Life for high mileage engines, 10W/40 (or lighter) should be good for this car.
Old 27-10-2016   #6
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Re: Ypsilon 1.4 12v
I've moved this from the mk1 punto to bravo/a section for you
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 27-10-2016   #7
Quote Originally Posted by brickfoot View Post
The Y is a LOT less car to drag around..so could mask some of the engines failings..
If its a nice example..and sensibly priced..why not have it
Charlie
Old 28-10-2016   #8
Netherlands
Re: Ypsilon 1.4 12v
Ok Thanks for the advice
But a small car with a fuel economy like a 2 liter.....
better not
i drive now a 1.1 fire but de body is not that good
this engine i now for the uno i had
Old 28-10-2016   #9
Re: Ypsilon 1.4 12v
better not
the Bravo/a, and marea are HUGE compared to the ypsillon,
it may even be the case of where a bigger engine gets great fuel economy..,
there are bound to be proper test figures around on the net for comparison..
Charlie
Old 30-10-2016   #10
Netherlands
Re: Ypsilon 1.4 12v
Oke so just listen too the engine there are no strange sounds
That might work
Old 27-09-2017   #11
Netherlands
Re: Ypsilon 1.4 12v
Hi to all ...it was a long time ago
But the car was a special voor me .original sunroof alcantra beige interieur wood on the dash en gold metallic on the outside with original alloy wheels.
the price was 500 euro so i bought it (foto,s are coming up)
the car is driven wel no smoke from the exhaust 267000 km en no strange sounds the gearbox is like new, little noise from the subframe but i have rubbers for mounting over the old ones
little restaurion to do on the floor rust left en the paint cleaning perhaps repainting but it is not al that bad.
i have to chance the cambelt because it sits about 6 years en 50000 km
Old 10-10-2017   #12
Netherlands
Re: Ypsilon 1.4 12v
here are the foto,s de camshaft is bad but after 270000km no wonder
de sparkplugs are looking fine also no oilsmoke en carter pressure
so i fink only replace the camshaft
Old 10-10-2017   #13
Re: Ypsilon 1.4 12v
Nice car, I think the camshafts were the weak point on the engines, but you will be lucky to find a new one or get a reconditioned one. Good luck!
Old 11-10-2017   #14
Netherlands
Re: Ypsilon 1.4 12v
i lookt on the internet ,and there were a few ones one for 70 euro,s en one for 160 euro i don,t no if er is a quitly problem whit it but 70 euro is for me to cheap
Old 11-10-2017   #15
Netherlands
Re: Ypsilon 1.4 12v
is this engine a new one from fiat i here story,s that is the old 1.4 from the Fiat Tipo so a Lampredi but i cannot discover a same thing only the short stroke
Thread Tools
(S) Ypsilon - NEED OPINIONS! MultiRacer Punto (Mk1) 3 29-08-2016 17:35
Chrysler Ypsilon wheels longdog Tech Talk 16 31-07-2013 18:18
Ypsilon better than 500 for a man? FiatFan2012 Lets Talk FIAT 25 15-05-2012 07:54
black Lancia Ypsilon BlueDan Spotted / Was It You? 0 10-09-2010 17:06
lancia Ypsilon MALINOIS Newbie Central 0 22-08-2008 19:28
