TheMiltos21
Hello guys, I found an ad of a 1.4 16V 95hp conversion out of a Lancia Ypsilon, for just 150 euros, with 84,000kms and the seller claims it's this low due to getting rid of stock.
Seller says it's got : motor, transmission, harness, ecu, driveshafts, keys, front suspension and brakes, starter, alternator, A/C compressor, motor mounts, exhaust and whatever else is needed for the swap.
http://www.car.gr/parts/view/5755127/
Anyway, assuming it's a good unit, isn't it almost a like-for-like swap just like swapping in with another 1.2 16V unit?
Our Brava is a '00 model with cable throttle and clutch, I can give you any other information if needed.
Could the 6spd Panda/Stilo box be swapped in as well if found?
Thanks!
Thanks!
