Hi can anyone enlighten me? cant see any marks on inj pump ,i have cam pulley and crankshaft sussed .a diagram would make me eternally gratefull .thanks for looking Steve
As to my very vast(not) knowledge of the fiat diesel engines. At work we just use tippex to mark 1 tooth, by they tend to move. Have a look for a hole in the pulley, if it has, try putting a 10mm head bolt in the hole. It may lock in position. I'll have a look for a diagram for u.
Hi thanks for that .Trouble is it snapped a belt,so i dont know where the pulleys were .i HAVE SEEN A ALLAN BOLT HEAD BEHIND THE PULLEY WHICH SEEMS TO CORRESPOND WITH A 14MM ISH HOLE IN THE PULLEY ,WHAT DO YOU RECKON?? I think it has probably done a valve or 2 knowing my luck !!But i wont know till i give it a spin .Do you know if its a freewheeling engine? Thanks Again Steve
The hole should just be a hole in the backplate of the timing belt, going physically into the engine. That's if it is this sort of pulley. I can't remember if its a freewheel or not. Your best way is to throw the belt on and give it a go. You can try just turning the crankshaft, just to see if it tightens up anywhere???
