I have a Fiat Brava 1997, 48000KM which I just bought.
When I use the second gear and increase the speed until it passes 40Km/h, I can hear a noise like vibration shortly (some seconds) from the gear box or around there exactly at this speed, it is not there when I use 3rd gear at the same speed. Also it happens when the car is stopped and I push the gas pedal to increase RPM and when I release gas pedal and RPM is decreasing at a special RPM you can hear this noise (vibration) comes for some seconds. Is it a problem and can be harmful or is normal?
