![]() | #1 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 | rear wiper problem Cheers guys, I got my front wipers sorted by stripping down the wiper motor to find it had water in. Dried out brushes, windings etc lubed with WD 40, now working a treat. However, my rear wiper is not getting water to the jet, due to a one way valve in the engine compartment not working properly, i think.( water jets out of hole on top of valve. Any suggestions.?? Cheers.
![]() | #2 | ||
Posts: 68 Thanks: 0 Trader Rating: 0 | Had the same prob on cinq i followed the pipe from bottle and found a small plastic insert in the line opened it up with a penknife blade and found the rubber valve had broke so took out the insides and replaced its worked ok since. mrf94
![]() | #3 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 | I had exactly the same on mine. Basically it stopped the jets working. I replaced the one way valve with a standard 'T' piece and they work fine now.
![]() | Body Stylist | Punto (Mk1) | 30 | 09-04-2005 18:02 |
![]() | IanB | Punto (Mk2/2b) | 5 | 21-05-2004 03:26 |
![]() | thefishdude | Punto (Mk2/2b) | 1 | 18-05-2004 05:15 |
![]() | cholmes0305 | Uno | 2 | 29-04-2004 20:47 |
![]() | kami | Bravo / Brava | 0 | 14-01-2004 17:14 |
