Digbydoodles
- Aug 11, 2005
- 2
- 2
Hi ya everyone
I wondering if you could help me please. I have recently bought a Brava 1.4s R reg(maybe a mistake after some of the threads I just read) and I am having problems with the gears. What happens is sometimes you can select gear as nice as you like but then you turn the engine off the problems start. The next time you start it up you just can't any gear, reverse crunches like you won't believe. You can eventually get into to gear but that is normally second. It has had a new slave cylinder fitted and the old one did have a hole in the gator. The system has been bled up and there is no air in it. A mechanic friend has said that he doesn't think that it is the clutch unless one has been fitting at a wrong angle, the reason he says this is because you can get gears sometimes and while I have driving it doesn't seem to be a problem at all but the garage says it is the clutch.
I just wondered if anyone had any experince of this or could offer some advice which would be greatly rec'd. Thank you for taking the time to read this
DD
DD
