I know, I know, you're all going to say just do a 20vt conversion but I've been looking into both and for (hopefully) simplicity, I am considering a 2.4 20v engine from the Stilo.
There is very little info on this conversion (from what I can find) for a Bravo. Seems it's been done on coupes a bit but the majority I can find is about using the 2.4 block with the 2.0t head and making a 2.4t. There seems very little about doing a n/a conversion.
Anyone able to point me in the direction of a build thread or at least some info on the process?
From what I can gather. The stilo engine is taller so there may need to be modifications to the bonnet (or engine mounts depending how you go about it) although this is coupe info, maybe the bravo bonnet is higher? otherwise, it should go in on the 2.0 20v mounts and mate up to the HGT gear box fine.
is it possible to use the 2.4 head and inlet or will i need to use the 2.0 head?
Any info possible please
