bravomalta
- Jan 15, 2014
- 5
- 2
I have a 1999 1.4 Ltr FIAT Bravo that has been running without problems for years.
All of a sudden a few days ago I went to start the engine and the KEYCODE light stayed on and I heard a clicking sound in syn with the INJECTOR WARNING LIGHT that keeps coming on and off. When I try to start the engine, it turns over but the engine doesnt start.
Sometimes the keycode warning light did stay on and i simply take out the key and insert it again and all was fine.
Initially my mechanic thought it was a problem with the keycode antenna and I changed that but the problem seems intermittent as a few days later I faced the same problem again with the 'clicking noise' and the injector light coming on and off (apart from the keycode light which stays on).
The mechanic ran a diagnostic but found nothing wrong with the car and its starting normally for the last few days. Now he's telling me that he's suspecting its an ECU problem ... which means an expensive fix, and im not too keen on changing the ECU if the mechanic himself isnt sure about it in the first place.
Any ideas on what the problem might be? I REALLY NEED YOUR HELP!!
