:doh:
Of course it is. What a Muppet! I see one drive past my house several times a week. Mind you it is a bit of a dog.
The Marea SW was a good looking car with its high rear lights and the split tailgate made it practical as well.
http://www.autotrader.co.uk/used-cars/fiat/marea
http://www.autosupermarket.it/search.html?npage=0
If you're planning to ship it to the US then an Italian model would be best as they tend to be less affected by rain and rock salt. You might find that diesels aren't your best bet either because although your gasoline prices are going up they're still a lot lower than ours.
Don't forget that any miles per gallon figures (mpg) you see published will refer to Imperial gallons which are almost 25% bigger than US gallons (well we had to have at least one thing bigger than Uncle Sam) so 25 Imperial mpg will be closer to 30 US.
Of the petrol engines they are all naturally aspirated, the 100 16V will be a 1.6 litre 4 cylinder with double overhead cams and 16 valves. The 115 is a 1.8 litre and the 150 is a 2 litre 5 cylinder with twin cams and 20valves and is the best of them, with that off-beat engine sounds like a refined Audi Quattro.
The ELX is the best equipped.....but then you've probably worked most of this out for yourself anyway. If you see the phrase MOT, that stands for Ministry of Transport, that refers to a basic roadworthiness test conducted anually after the car is 3 years old and includes lights, tyres, brakes, suspension, steering, emissions and other basic safety aspects.
I don't know whether right hand drive will be a big problem but although Italian cars will probably be less rusty and have the wheel on the correct side for you, but buying from here, or Ireland, will help with the buying process as at least you'll be able to talk to the seller in the same language.
Keep us posted if you will.
Oh, and by the way, you won't have to give anyone a finder's fee, we're all pretty helpful on here.
