MadBravaDriver
Hello all,
I was at a Fiat dealership yesterday concerning a problem with the air pressure sensor... (second time in 9 months) and some of their answers troubled me...
They charge me 180 euros and I found it at a friend for 100 euros...
And now my question... is it a straight fit or I need to adjust anything else?
Also when I mentioned to them a reset of the ECU by disconnecting a battery lead overnight, they told me that this applies only for models from 1999 and back and not for my model 2001... does anyone know if this is true? Also they told me than an action like that, would mess up with other electronic components of the car... true or false?
cscotson in another thread mentioned:
I have that tappet noise from my valves and that screeching noise only when the engine is cold... I change oil every 5000 km and the Fiat Dealership told me that it is normal and nothing to worry as the valves are self-regulated and the screeching sound exists till the pressure of the oil becomes high...
To be honest I do not trust them... In your opinion I should procced to a camshaft change before it is too late? or is it something else?
Thank you in advance.
There is an inherent problem with the top end of the 1.4 12v brava engine. What can happen is that if the oil is not changed regularly, or you use the wrong grade of oil, the spray bar over the camshaft can become blocked.
The spray bar delivers the oil through *very* tiny holes onto the lobes of the camshaft. I've been advised that the oil pump on the 1.4 is rather weak, and does not deliver enough pressure to keep these holes open under these circumstances.
In these cases, what will happen is that the lobes on the camshaft will heat up and wear rapidly. You will first notice a "tappet" noise, followed by an ear splitting screech. Eventually the engine will seize.
