You would need the switch, the wipermotor itself and then do additional wiring.
For the interval function you could just get aftermarket kit.
Its basically a adjustable timer you plug it to the singe wipe contact.
Velleman K2599 is one, but it does not give much range, looking at the schematic you could replace the switch with potentiometer to get seamless setting.
