F Fiatrick New member Joined Nov 26, 2011 Messages 58 Points 28 Jan 28, 2012 #1 wondering if you take the entire airbag system from a fiat marea and swap it with the system in a bravo/a. meaning you take passenger airbag, drivers airbag the entire loom and the control unit. is it possible ?
m20b25 Patron member Parked in the garage Written a guide Joined Jan 19, 2009 Messages 3,214 Points 595 Location Kilberry, Meath Jan 28, 2012 #2 Yes it is Use the modules, clockspring and wiring. MickeyBravo has a Marea wheel with working controlls in his HGT You could put in an Alfa 156 wheel either
OP OP F Fiatrick New member Joined Nov 26, 2011 Messages 58 Points 28 Jan 29, 2012 #3 will it also work if you take the controllunit and drivers side and passenger side airbags? if you for example aren't able to aquire the entire loom ?
