F Fiatrick New member Joined Nov 26, 2011 Messages 58 Points 28 Nov 28, 2011 #1 hi, i'm in need of answers on how to remove this bravo/brava/marea radio facia plate thing, hopeing for a quick answer
OP OP F Fiatrick New member Joined Nov 26, 2011 Messages 58 Points 28 Nov 28, 2011 #2 http://www.ebay.co.uk/itm/Fiat-Marea-Bravo-Brava-CD-Radio-Fascia-Panel-FP-01-00-/250704938517 Last edited: Nov 28, 2011 This post contains affiliate links which may earn a commission at no additional cost to you.
m20b25 Patron member Parked in the garage Written a guide Joined Jan 19, 2009 Messages 3,214 Points 595 Location Kilberry, Meath Nov 29, 2011 #3 The radio needs 2 u shaped blades to take out. I used 2 knives per side The facia just clips in or sits in position. Unless it has been glued
OP OP F Fiatrick New member Joined Nov 26, 2011 Messages 58 Points 28 Nov 30, 2011 #4 Thanks i got it out. had some burned light bulbs in the center facia. got em replaced with some led ones -works fine.
