I’m trying to install some DRLs (Daytime running lamps) on my 1.6, 2001 Fiat Bravo. The kit I bought comes equipped with a module that automatically turns off the DRLs when you switch on the low beam.
It’s all good, all the wires are in place, the only problem I have is that I can’t find an ignition switched 12v feed in the engine bay somewhere. Inside the car, under the steering column I can find it, but its hard to run a wire from there until the front, where the headlight are.
So, can anyone help me? Tell me, what wire do I need that has an ignition switched 12v feed in the engine bay.
Thanks.
Thanks.
