![]() | #1 | ||
Posts: 1,151 Thanks: 12 Trader Rating: 0 ![]() | Window Motor Has anyone replaced theres? If so how do you get that pladtic bolt/bullet thing out of the window and vice versa? Seems impossible to get out. With summer being here can do with both windows working. Help apreciated Cheers Mike
![]() | #2 |
Posts: 3,194 Thanks: 105 Trader Rating: 0 ![]() | Re: Window Motor Does this post help? I'll take more pics of stripped doors if you need them ![]()
__________________ The ultimate driving machine, the real M20B25 ![]() "Ride me sideways" VAN-dalised Bravo ![]() ![]() Small, fuel economic, environmentally friendly Alfa ![]() I am this gombeen ![]() |
![]() | #3 |
Posts: 1,151 Thanks: 12 Trader Rating: 0 ![]() | Re: Window Motor its bringing up page 4,theres nothing about removing a window motor? i can get the actual motor out,not a problem only 3 nuts then the 2 on the frame.Just cant get the plastic thing out of the window.I didnt wana force it incase i shattered the glass :s
__________________ ![]() A Fiat Marea in a Bravo shell...its good to be different ![]() Now with working Steering Wheel Controls FC Performance Chip. Currently sorned |
![]() | #4 |
Posts: 1,151 Thanks: 12 Trader Rating: 0 ![]() | Re: Window Motor sussed it ![]() after reading this thread it came clear what bit i had to remove: https://www.fiatforum.com/punto/6256...dow-motor.html i was trying to remove the whole lot (as i received the whole lot) trying to get that plastic lug out of the glass seemed impossible.Only to find out the motor is attached to the reg at the end with 3 screws.I know the motor works as i tested it ![]()
![]() | #5 | ||
Posts: 28 Thanks: 0 Trader Rating: 0 ![]() | Re: Window Motor i had to do the reg on the wifes last year, went up thje breakers yard blind as to what it took to get it off, Real pita first time around, but you need the arms of a baby with the strength of an adult to get the small plastic circlip like peice out from the out side of the door side of the plastic lug that holds the window onto the reg rails, simple enough once youve sussed it, just make sure you tape the window up - duck tape, as that makes it a lot easier!!
![]() | #6 |
Posts: 1,151 Thanks: 12 Trader Rating: 0 ![]() | Re: Window Motor yer i taped the window up using thick selotape roll to begin with.the little loop thing has snapped off inside i can just feel the 2 bits hangin ![]() But hopefully i wont have to remove the whole reg as its just the motor thats packed in and that can be removed easy enough ![]() we shall see tomorrow...
![]() | #7 |
Posts: 1,151 Thanks: 12 Trader Rating: 0 ![]() | Re: Window Motor Sorted! ![]() Eventually i managed to get my hand in the door and remove the motor (having a magnetic screwdriver is very handy!)..only to find whilst removing the motor from the regulator i received that the actual motor is different.The spindle is smaller and thiner ![]() ![]() After all this faffin about trying to get the whole reg off yesterday it must have just been a faulty plug OR the plug had worked its way lose from lasttime i got a garage to fit the present one.So all in all i didnt need that motor lol Also it turns out to be from a year 2000 as the date shows on the sticker and also non of the numbers match. Mad how a mk1 97-99 differs to a mk2.2000+ I now have 2 WORKING windows and a sunroof again ![]()
![]() | MickeyBravo | Bravo / Brava | 0 | 14-06-2011 22:33 |
![]() | Hobgblin | Sedici | 5 | 14-01-2011 11:53 |
![]() | malty123 | Punto (Mk2/2b) | 7 | 25-04-2010 21:39 |
![]() | Timmo | Bravo / Brava | 5 | 08-01-2009 08:50 |
![]() | Rustbucket | Barchetta | 6 | 26-09-2007 13:51 |
