Old 01-05-2011   #1
Front subframe
Went to have my alignment looked at after changing both track rod ends.
Turns out that my front subfreame is well on its way out.
Where can i get a new one?
How much am i looking at for parts and labour?
Daviedaly is offline Reply With Quote Quote
Old 03-05-2011   #2
Re: Front subframe
Anyone any ideas or is this car for the scrappy?
Old 03-05-2011   #3
Trader Rating: 1
JoskeJTD has donated!
Re: Front subframe
To remove it you must undo the wishbones, Arb droplinks, exhaust downpipe, Exhaust heatshield needs to be lowered, centre engine mount.Then the 8 subframe bolts.
Get a 2nd hand subframe from a scrapyard anywhere between 30-100 depending on yard. Think Fiat want 400.
Thanks Daviedaly thanked for this post
JoskeJTD is offline Reply With Quote Quote
Old 03-05-2011   #4
Re: Front subframe
Thanks joske.
With v.a.t fiat want almost 600!
Think il ring a few scrappys after work!
If i get the part how much do you think to get it fitted? Just labour?
Is there anything else that i might need?
The one thats on it is crumbling and bent causing heavy wear on the front drivers side tyre. I just replaced the track rod ends and went to kwik fit to get the tracking done and it was the guy in there who spotted it so havent had it looked at properly by a mechanic.
Old 03-05-2011   #5
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: Front subframe
Only way to get an idea of labour is to talk to a garage.
Make sure the replacement is in good condition - maybe get it grit blasted and painted. You can confirm from the eper which other vehicles will have the same subframe.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 03-05-2011   #6
Re: Front subframe
Phoned the scrappy, 50.
Damn sight better than 600!
So how do i go about getting it grit blasted?
Also what sort of paint should i use?
Is it possible that this could be a waste of time if the holes for the bolts and stuff are corroded aswell making them useless?
Thanks very much for the help i need to get this sorted asap as im not feeling entirely cimfortable driving it!
Old 03-05-2011   #7
Borneo
Re: Front subframe
when you say the subframe is on the way out what do you mean, they are fairly substantial parts, is it rusted through? You can do this as a DIY job, just needs few decent tools sockets and spanners, axle stands. Sub frame is held on by about 6 m12 bolts under the firewall, 2 long bolts onto the chassis rails. The steering rack, rear gear box mount, anit roll bar, and wish bones are attached to it. They all unbolt, the only threaded thing on the frame I can remember is the rubber engine mount in the middle which is for the gear box mount.
Oh hang on I'm in the same town as you, G41 area, maybe you'd like to come my way and I'd give some advice if you like.
sediciRich is offline Reply With Quote Quote
Old 03-05-2011   #8
Re: Front subframe
Its rusted through i didnt have time to look properly as i was in kwik fit!
That would be brilliant i work on duke street at the hovis factory do you know it?
Old 03-05-2011   #9
Re: Front subframe
If you guys do this, be sure to make a guide (Y) Save the community even more money and earn alot of respect! haha :P
Likes Michael Dranfield liked this post
MrMigs08 is offline Reply With Quote Quote
Old 04-05-2011   #10
zombie nation
Hellcat's Avatar
Trader Rating: 3
Re: Front subframe
I had a tipo subframe rust through in a couple of places. A garage cut it back and braized new metal in. Dunno if yours is beyond this?
Old 04-05-2011   #11
Re: Front subframe
I dont know how bad it is but the guy in kwik fit said he wasnt comfortable standing under it!
So pretty bad i would guess.
I have a friend who is a mechanic but getting a hold of him is a nightmare but once i do il know more about it.
The guy in kwik fit thinks its done though.
Old 04-05-2011   #12
Re: Front subframe
I just did mine took me an 2 1/2 hours but i did have a full workshop to play with.
https://www.fiatforum.com/bravo-brav...sub-frame.html
jimmyybob is offline Reply With Quote Quote
Old 04-05-2011   #13
Re: Front subframe
Jimmybob what tools did you use.
I.e socket sizes and stuff dont want to go to this scrappy on saturday without the right tools for the job!
How difficult was it?
Did you get yours second hand and refurb it or was it new?
Did all the bolts go back in ok?
Old 05-05-2011   #14
Borneo
Re: Front subframe
You can get a frame sent to you from this chap, http://www.fccuk.org/forum/ubbthread...oard=48&page=1
but to remove, you needs a socket set, spanners. The bolt holes are just that holes only 2 of them are threded, the others have the thread on the bits you remove for example the wishbones - the bolts go through the frame and into the captive nuts on the wish bones. This picture gives an idea of whats on it
Likes lukish, Michael Dranfield liked this post
Old 05-05-2011   #15
Re: Front subframe
Cabt see anything on there for subframe. Also its a coupe site? Will the coupe subframe fit a bravo?
(T) rear subframe front bushes needed multipete Multipla 26 04-08-2011 17:52
(T) mk1 punto front subframe nikkiy9 Punto (Mk1) 4 10-09-2010 15:37
(T) Front Subframe rear bushes josh180984 Stilo 2 06-06-2009 19:44
(G) The fun never ends, does it? (Front subframe now) Xen Punto (Mk2/2b) 2 17-06-2007 21:16
