im Axle Specialists
Thread Tools
Old 11-03-2011   #1
Denmark
problems with cylinder firing order.
i'm new here. a friend of mine just got a bravo 1.4 sx 1996.problem is it's not starting, becouse in his attempt to change the ignition coil and HT leads resultet in him messing up and forgetting the posistion of the ht leads, both on the ignition coil and the engine block.
could you please assist, in how to propperly place the ht leads from ignition coil to spark plugs on the engine?
patrickwm is offline Reply With Quote Quote
Old 11-03-2011   #2
Denmark
Re: problems with cylinder firing order.
everything we tryied, ends up in engine missfiring, then stops.
Old 11-03-2011   #3
Romania
well the coil pack should have the cilynder order on it ( 1,2,3,4 )
i can't remember where cylinder1 is .. could be the closest one to the coil pack or the one at the other end.
try both!
after you find cylinder 1 the rest are easy 2,3,4.
aurick86 is offline Reply With Quote Quote
Old 11-03-2011   #4
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
The coild pack has the cylinder numbers printed on, so does the cylinder head but they are harder to see. Anyway...
Engine order is;
Cambelt | 1 | 2 | 3 | 4 | gearbox
Coil pack order is;
Adrian Bravo is offline Reply With Quote Quote
Old 12-03-2011   #5
why washe changing the coil to begin with? was it doing the same before?
clock34 is offline Reply With Quote Quote
Old 14-03-2011   #6
Denmark
okay.
så number 1 on the coil goes to cylinder 1. and 2-2, 3-3, 4,4?
or is it wrong ?
Old 14-03-2011   #7
thats right
Old 14-03-2011   #8
Denmark
okay, thanks it worked. it starts, but it's very irregular/uneven.
tested ignition coild. ht leads, and spark plugs. don't know what else it could be. any ideas ?
Old 21-03-2011   #9
Romania
Could also be:
-the stepper motor, wich controls the idle;
-dirty butterfly case;
-broken throttle position sensor (also on the butterfly case);
-broken TDC sensor (rpm)
-broken camshaft sensor.
Pick one and test it. Or test all.
-stepper motor: easy test - take it out leave it connected, and put someone to fire up de car, if the pin moves, that means that the motor is trying to adjust the air bypass => it works.
-dirty butterfly case: clean it.
-broken throttle position sensor: you could check it with a multimeter (don't remember what ressistance should have), but you could also change it cause is pretty cheap.
-broken TDC sensor: check it with a multimeter, should have somewhere between 750 ohm - 900 ohm, at 23 degrees Celsius.
-broken camshaft sensor: check it with a multimeter (don't remember what ressistance).
You could also try to take it to a tester, to see if it gives up anything.
Good luck.
The universe and stupidity are infinite. And for the universe i'm not sure .
Corvinus is offline Reply With Quote Quote
Old 25-03-2011   #10
Denmark
okay. i will try that. only problem is: where are these things located ?
Thread Tools
(T) cinq sporting firing order phillyd Cinquecento / Seicento 10 22-09-2010 22:53
firing order coreynz77 Newbie Central 2 10-06-2009 06:48
(T) punto55 firing order alby Punto (Mk2/2b) 1 09-10-2006 14:06
(G) firing order hensteeth Panda (Classic) 2 06-05-2006 18:55
(T) FIRING ORDER alpunto Punto (Mk2/2b) 1 08-05-2004 00:12
