Thread Tools
Old 11-03-2011   #1
Help With a Few Things!
Hi I recently bought my first bravo the other day! (orange 1.6 HLX) and need some help with a few things...
the left side windscreen washer jet doesn't work but the right one does? i have looked to see if it connected under the bonnet and it looks asif there are no blockages.. any ideas?
another is when i use the washer jets the wiper blades don't come on, i have to put them on, its this right? all the other cars i hav had has done it automatically?
The rear washer doesn't work but the wiper does? i have looked at threads saying the pipe could have disconnected but i haven't had a chance to look yet, but no signs of dampness...
Boot lock seems seized completely, key wont turn in it (maybe this has something to do with a leak from the rear washer?) is this an easy repair?
I have a aftermarket alpine cd player installed but i need to remove it to plug the USB iphone cable in the back, do i have to disconnect the battery? i really scared that if i do this i will have to get keys programmed again etc.. have two blue keys and the previous owner is sending the red in the post!
thanks for any help you can give me on any of these! hope to be a regular here for a long time
TC18 is offline Reply With Quote Quote
Old 11-03-2011   #2
Re: Help With a Few Things!
Hi only thing i can help with is the rear washer. Theres a guide on the fiat boo website. Mine was the same and i followed the guide and now i have a nice clean rear window! Its nice to be able to see now!
I also have the seized boot lock its a bit annoying. Would like to find out how to sort that aswell!
Last edited by Daviedaly; 11-03-2011 at 17:21. Reason: Fat fingers on the i phone!
Daviedaly is offline Reply With Quote Quote
Old 11-03-2011   #3
Thanks for the reply, got a day off tomorrow so i will be giving it a good wash, de-badging the faded badges, fitting new speakers and sorting out the iphone connector, cleaning the interior and alot more lol il have a look at the lock barrel see if it can be fixed, il let you know how i get on!
Old 12-03-2011   #4
rear boot lock, spray grease it and keep putting your key in/out loads, then keep trying to turn eventually it will work. keep going till its smooth (dont use wd40, use spray grease)
rear washer, mine had no leak but didnt spray, it was the little one way valve under the bonnet behind the fuse's near the passanger suspension top mount, replaced that and it works fine!.
front wipers should work with the spray.
remove the battery and you wont loose the key code, also for messing with the stereo TBH i never remove the battery anyways, as its a pretty safe thing but if you want to be sure dont worry about your codes going missing.
spray only working on one side?. mine sprays only the driver the first time i pull it and when i release and engage it again it does the passanger only, i know they both SHOULD work togeather but mine dont and i CANT work out why. mabee try renewing all the one way valves (little black circles with a triangle on it) with new ones as i am going to, should fix everything as they are the only things that can go faulty (get stuck open/closed)
clock34 is offline Reply With Quote Quote
Old 12-03-2011   #5
Gave the car a really good wash and wax today and debadged it! I don't think the previous owners had ever done it, tar spots (i think) everywhere
Took the head unit out and threaded the ipod lead through only to find that it was not the right connector on the back! grrr had to go out and buy the correct one! 29
Took the cover thingy off the back of the boot to see if the washer pipe had come loose but it hadn't! looks as if i do need a new valve! next on the list is new door handles.. ebay prices are crazy have to have a hunt around the scrap yards
Old 12-03-2011   #6
Quote Originally Posted by clock34 View Post
Thanks! had a look at it was gonna put some spray grease in it but couldn't find it
Old 12-03-2011   #7
Hi
There's some suggestions of mine below. Hope it helps
Quote Originally Posted by TC18 View Post
It could be blocked, otherwise if you remove the the bonnet liner you will see a 'T' with one hose connecting to the washer and the other one continuing to other (non-working) jet. That 'T' has a diaphragm that must be knackered. Replace the T and you will have both jets working.
That's the way it does .
As it has been suggested, there's a good guide on the BOO. I also found out that the hose may split nearby the hinges. That's what happened to mine. Don't remember exactly how to remove the gaiter rubber, but it must be a simple job because I did it .
nunesaf is offline Reply With Quote Quote
Old 12-03-2011   #8
what i ment when i said it should as to wipers moving. i ment yours is doign as it should they dont move on their own lol.
Old 12-03-2011   #9
thanks for the replies
i took a very very small part of the bonnet liner off just to see if it had come off didnt really get a chance to take it completely off due to it getting dark! another job for tomorrow
really love the car for the amount of money i paid and its nice to have power steering!
Old 13-03-2011   #10
bluejohn125 has donated!
Front washer jets are a common problem, you can pop them out quite easily and soak them in warm soapy water then carefully clear the holes with some fine wire. But new ones from Fiat are dead cheap anyway.
bluejohn125 is offline Reply With Quote Quote
Old 13-03-2011   #11
Quote Originally Posted by bluejohn125 View Post
did exactly that this morning, along with cleaning all the shuts. i now have two working jets next on the list is to get the marea front lights and new bulbs all round and some tax
Thread Tools
(G) ok,just a few things jonpeck Punto (Mk2/2b) 2 02-01-2009 23:34
(G) relocating things to make room for things. arc Cinquecento / Seicento 17 30-07-2008 23:15
(G) Two things crashbang Stilo 0 23-06-2006 07:23
(G) Few Things I Need.. Anyone? Adamski Cinquecento / Seicento 7 27-04-2005 12:21
(G) few things! wkd cinq Cinquecento / Seicento 3 19-04-2005 19:22
