Old 02-03-2011   #1
m20b25 has donated!
Ireland
Immobiliser issue
Hi all!
Sometimes in the new car, the code light wont go off and the car just will not start. Then after a few minutes, all will be grand and it will start no problems. It seems to take fits of this....
The key has been "shaved" ie the keyring end has been broke off, smoothed and a hole drilled through the key for a keyring...! Is my key wonkey or is the problem a bit more sinister? My dads car suffers the same problem but only when the starter refuses to work (needs a new starter) it will start with the code light on (suspected faulty dash). Getting a key cut and coded is not a problem. Neither is getting the key, ecu and immobiliser changed but i would like to try and avoid that...
Any help is appreciated!
m20b25 is offline Reply With Quote Quote
Old 02-03-2011   #2
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
Re: Immobiliser issue
Probably the easiest think to have a look at is the aerial wire especialy bacuse you have lots of spares
its the black wire shown here. The hoop sits around your ignition barrel. People have had bad aerials before.
The immobiliser bit in the key is a little black pill looking thing or a grey chip, its probably not physicaly damaged. If its your only one though I would get a copy of the chip done while you still can, maybe its about to fail.
You can see the chip version here nexto the battery. The black pill looking chip would be in the same spot.
Thanks m20b25 thanked for this post
Adrian Bravo is offline Reply With Quote Quote
Old 02-03-2011   #3
m20b25 has donated!
Ireland
Thanks Adrian! I didnt think of that ring, i must change it when i get the chance and see how it goes from there, it worked well in the old car... Hopefully getting a key on sat so that will eliminate the dodgy key. Thanks again and ill keep you posted
Old 04-03-2011   #4
m20b25 has donated!
Ireland
Now I was driving this car last night, no problems whatsoever. This morning I got into it to move it so I could have comfortable space to work on it and it refused to decode. I changed the aerial in situ but it hasnt made a difference I did notice the code box wasnt in its place, maybe they had this problem before... Does this mean I have to change everything? Ie locks, box and ecu?
The ultimate driving machine, the real M20B25
"Ride me sideways"
VAN-dalised Bravo
Small, fuel economic, environmentally friendly Alfa
I am this gombeen
Old 04-03-2011   #5
Speedbump grimacer
Trader Rating: 1
Easiest thing to do is change the ECU the immobiliser and the chips in the keys. That way it saves changing all the lock barrels or sending the ecu to a specialist.
Old 04-03-2011   #6
m20b25 has donated!
Ireland
It was indeed the immobiliser itself, i swapped the unit and ecu, put up the old key to the ring and it works without any problems! Just need to work the chip into a new key and i hope all is solved then. Thank you for your help
Old 04-03-2011   #7
Romania
you have multiple ecu + imobilisers.. can't you figure out how to emulate the signal from the imobilizer?
i would think it would be just something like bridge-ing some connections
aurick86 is offline Reply With Quote Quote
Old 05-03-2011   #8
reddy4bed has donated!
Quote Originally Posted by aurick86 View Post
In your dreams!, no-one has driven these cars away without the correct key.
Tony.
Thanks T14086 thanked for this post
Likes Adrian Bravo liked this post
reddy4bed is offline Reply With Quote Quote
(G) immobiliser? Dorian Multipla 1 25-04-2010 08:54
(T) My new...immobiliser? 5abr3 Punto (Mk2/2b) 11 07-05-2008 17:31
(G) help immobiliser jarred Ulysse 7 28-07-2007 23:19
(G) immobiliser gazzauk Multipla 1 15-01-2006 15:00
(T) Immobiliser gls Cinquecento / Seicento 7 20-01-2005 18:51
