Technical headlight relay ?
i always thought there was. no way the entire power for the headlights runs through the stalk. no way at all.
did you test the bulb plugs for power? is it getting that far? if not follow them back and test every connection see where the power stops.
According to service guide there is relay for dimmed lights.
Tony,
I've been out to my Bravo (same year and model as yours), put the headlights on and I've pulled every relay out in turn and the headlights stayed on throughout :bang:
I tried the relays behind the steering wheel/dash, the ones behind the glovebox and the ones in front of the battery and nothing.
I can't even hear a relay click when I switch the lights on.
I hope this helps a little bit, I know it's not the answer you were looking for but it might help towards the fault finding ;)
I'll keep looking after dinner and see what I can see!
Lee
