Calling all good fiat mechanics, after changing head gasket getting head skimmed, replacing cambelt and tensioner. The big day arrived, the engine started first time, but is reving up and down high on its own, with a lot of white smoke. I expecting some as water had entered the engine. But not this much its seems the choke is stuck on or something. The engine sounds fine apart from this problem. Any idea what this could be, I have checked all connections, and everything is back to normal. I was thinking the Idle air control stepper valve or the
Throttle Potentiometer Sensor as they are known.
kevin
kevin
