General HELP NEEDED lol engine problem
J05H
bolton
Hi here is my problem, i have a 1.6 100sx bravo. when the car is idleing if i tap the accelerator a few times the revs drop and the engine just cuts out. I ve had a look at the obivous but had no luck. alsosometimes when i stop for lights or junctions it will be idleing at 1500rpm till i rev it abit and then it comes back down to normal but this fault is intermitant. not sure if the two are related. thanks in advance josh :mad:
Hi, I solved this idle saga after years. Problem is bad contact in fuse-box connector. You find this big black connector behind the battery. Take it apart, clean with wd40 and dry.
Also cleaning of throttle body is advicable if you have you never done this before.
