Its a simple one, window goes down but wont go up on my Bravo. New switch, still dosent work. Do the window regulators give much problems if the car has been standing for a while? Also where are the relays for the windows? Cheers people
My daughters Bravo had the same issue.
Relay is the big black one at the back of the glove box on the nearside. It also opertaes the sun roof, so it's not likely to be that.
Use a flat screwdriver to lever the switches from the door panel. Should come out quite easily.
Check the power SUPPLIES to the switch. The 2 outer ones should be live with the ignition on, IIRC. Try "shorting" the switch. If the motor whirs into life hit Ebay for a new switch (you can't dismantle them --- I've tried).
If not then try the big cable where it comes into the door. Twist the nut and disconnect it. Clean the connections you can get at. Plug it back and there should be a decided "click" when it goes back.
Still not working? Remove the door card. On my daughters the plug had worked it's way off the motor. Spot of superglue and some tape sorted it.
Hope that helps.
There's a thick bunch of cables that comes out of the door pillar by the hinges.were is this magic plug?
