Well, I finally got the tubes off of the old matrix, but I only did so by breaking off the plastic flange and first inch or so of the plastic tubes on the unit in order to free the rusted-in aluminum tubes. I assume the tubes are re-usable if I clean the ends with emory cloth, yes?
Yes, it's quite tight getting the old one out, and, I had to cut away a little bit of the black plastic holder right above it which holds two connectors (one black one white, both of which I moved out of the way first.)
It appears however that I will indeed need more clearance in order to install the new one. Is the ventilator removal straightforward? Is there a pictorial or step-by-step guide you can refer me to? THANKS again for all of your help.
(This may need a different thread, but, in an effort to access the area under the heater assembly, I attempted to remove my center console. In the end it wouldn't clear the handbrake lever, but, I did remove the gear shifter knob, and, I moved it with the knob off! Now, after re-assembly, the gear shifter goes into: P, N, R, D, and 3, but not down to 2 or 1. Also, it sounds rather 'springy' while I move the lever. Q: Serious problem?? (Hope not...) Or only requires a minor fix?)
