HI all dont know whats wrong but the heater isnt working properly and the dial only goes up halfway between c and normal.any ideas and how to do the job would be appreciated
about the heater it might be a thermostat shut close but if that is the case the temp should rise very high. Does the fan kicks in alot? if that is the case the gauge might be faulty. Another thing, it might be air in the sytem.
To find it go to the engine bay, put the right hand on the radiator, and follow the rubber tube that goes in the top of the radiator.
this should get you to the thermostat
