im Axle Specialists
Old 11-11-2010   #1
Clutch Slipping
MY clutch is slipping in my p reg 1.6 Bravo. Its not that bad at mo and has only done 31,000 genuine miles. Could it be a problem with the hydralics or fluid or is it just prob a worn clutch? Got a quote for 155 to get fixed which I think is reasonable but also need two new wishbones and 2 cvs. Dont have cash to get them all fixed. Do bravos suffer from common clutch problems?
allandoc is offline Reply With Quote Quote
Old 12-11-2010   #2
JLenno has donated!
Ireland
Re: Clutch Slipping
Quote Originally Posted by allandoc View Post
Not that i know of. Was this car idle for some time by any chance? Make sure aswell that it is the clutch and not the gearbox. I though it was clutch in my one, the revs would go nuts and the car would barely move! A week later my gearbox went and my clutch was perfect.
JLenno is offline Reply With Quote Quote
Old 12-11-2010   #3
m20b25 has donated!
Ireland
Re: Clutch Slipping
Check the slave cylinder, its bolted on top of the box, this could be fecked and causing your problem...
The ultimate driving machine, the real M20B25
"Ride me sideways"
VAN-dalised Bravo
Small, fuel economic, environmentally friendly Alfa
I am this gombeen
m20b25 is offline Reply With Quote Quote
Old 13-11-2010   #4
Re: Clutch Slipping
Quote Originally Posted by m20b25 View Post
how do i check the save cylinder. the car was sitting idle for a while before i bought it
Old 13-11-2010   #5
Coupe 20v W/Fc Chip
Bravo16VSpoonz's Avatar
Bravo16VSpoonz has donated!
Re: Clutch Slipping
if you want some room, take the battery out and the tray...its on top of the gearbox, with a 'nipple' point upwards....you cant miss it just check that the rubber hasn't perished..
try bleeding it too, might help....
does it go in gear fine though ?
Coupe 20v Turbo
Bravo16VSpoonz is offline Reply With Quote Quote
Old 14-11-2010   #6
Re: Clutch Slipping
Quote Originally Posted by Bravo16VSpoonz View Post
Yes. It goes into gear no problem!
Old 14-11-2010   #7
Re: Clutch Slipping
A faulty slave won't make your clutch slip. However if the car had been standing for a while it is possible for the clutch operating arm to partially seize up, holding the clutch half in. Although 31k is'nt a lopt of miles it's not exceptionally low, so could be it's just worn out.
flying clutchman is offline Reply With Quote Quote
(T) Clutch Slipping stewieg Bravo 19 05-04-2012 22:05
(G) Clutch Slipping???????? wapinthecorner Marea 14 11-08-2010 22:29
(T) Slipping clutch Digimods Punto (Mk2/2b) 15 11-08-2010 09:14
(T) 2.8 clutch slipping! Autodetailer Ducato 4 07-10-2009 18:41
(T) Clutch Slipping? reaper1988 Bravo / Brava 10 18-12-2006 17:40
