Old 30-07-2010   #1
Sump plug washer
Hi folks, I'm about to attempt my first ever oil change haha and need a quick bit of advice. I have a Fiat Bravo 1999 1242cc 16v 80sx, and am aware that a 12mm hex key is needed to open the drain plug. Where can I purchase a new washer seal for this, or can I just use the existing one? If not what size of washer am I looking for? I take it, its just an odinary washer that I can buy from a hardware store? Thanks
Callum
callumfletcher is offline Reply With Quote Quote
Old 30-07-2010   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: Sump plug washer
Based on the Seicento and Grande Punto I've done, neither had a washer/seal/o-ring. However, the oil filter does have a seal and the new filter will come with one attached - I assume you're changing the filter as well?
Eklipze3k is offline Reply With Quote Quote
Old 31-07-2010   #3
the stig/130 has donated!
doesn`t have a washer, due to being threaded in, and using a allen key,
the stig/130 is offline Reply With Quote Quote
Old 31-07-2010   #4
Moderator
Andy Monty's Avatar
Andy Monty has donated!
more down to the sump plug been tapered torque it up and it shouldn't leak
Massive gash
Just a little touch up
(G) jtd sump plug washer? pieandapint Stilo 1 23-06-2008 12:34
(G) Sump Plug Washer Matt925 Cinquecento / Seicento 2 08-04-2006 18:51
(T) Sump plug washer size? CaneyJ Cinquecento / Seicento 15 16-06-2005 11:35
(T) Sump washer? AIJ29 Cinquecento / Seicento 3 09-12-2004 20:17
