Technical Dash Lights
saggiemaggie7
Electrical fault dash lights + fuel pump
Hi when i turn ignition on in the car i only get the handbreak light, airbag light, battery light and oil light coming on and no sound of fuel pump kicking in any idea why this could be was all working fine other day now its getting nothing and obviously no fuel pump kicking up means no fuel and no start pleaseee help
tried fule pump fuse that is ok and if the dash fuse is out wouldnt it stop the the lights that are coming on working?
Just Checked all fuses with a test lamp near steering wheel and they are all ok checked the fuel pump 1 earlier on
just to let you know the code key light is not coming on normally when ignition comes on i hear the fuel pump going and i get the key code light come on then go off neither is happening
Bump Tried Removing Battery and reconnecting still the same problem need this sorted ASAP what would cause both things to happen its as iff only half of the ignition sequence is working normally as soon as you put the key in the code light comes on and you here the fuel pump going hat would cause both things to fail?
just been out to the car yet again and located the fuel oump checked there is no live feed getting to it however the fuse is working power is getting to the fuel gauge but not the pump tried every fuse in the car they are all ok unless any are hidden its as if none of the engines electrical components are fireing up but live feeds are going everywhere as should be as i have checked everywhere i could with a test lamp im proppa stuck on this 1
Apologies if it's been already mentioned, but does the code key light come on and then off again as it normally should before you turn on the ignition?
