hi guys recently my injector light has come on along with the abs light and the abs has started hesitatin under hard acceleration one of the injectors looks like its seen better days could this be causin the problem i havin ?
Looks like it. Injectors wear out...they are simply a high speed solonoid operated pump. One is duff and the injector light is telling you of the fault.
hi guys did some investigatin and had a oil leak on cylinder seal 1 and look like it had damaged the coil pack so i did the rocker cover gasket and changed the coil pack all was ok for a few days and ran spot on but now the injector light and abs light are coming on every now and then and is accompanied by a bad misfire any ideas cheers
