Hi i have been offerd a 1998 fiat brava 1.6sx but the car will not start i have been told it is ECU problem but i don't have the red key if i change the ecu will i need the the red key for my car or the car i get the ecu off Thanks Ste
Hi i have got the car running but is sounds like it is running on 3 cylinders i have tried a new coil pack and no change anyone got any ideas what it could be Thanks Ste
Hi there, stating the obvious, have you checked the ht leads and plugs? Is there a red llight on the dash board that looks like an injector? These engines suffer from injector failure so that could be your problem. They get hot as they are buried right close to the engine and have the inlet wrapped right round them so there is little or no airflow over them.
