im Axle Specialists
Old 06-03-2010   #1
Smile My first Bravo
Trofeo 16V 80 1242cc 86K on clock Wreg
Airbag light on. Is it a similar fix as the Multipla ie WD40 on the contacts under the seat?
Smooth performance (was my brother's and he took care of it) though there is the slightest vibration in the 30-45mph band when gentle acceleration. A bit worried about not finding any old repair and service bills for a belt change!! Probably need to see to that. Any idea on the slight judder. Should probably get a fuel filter change.
Has had two cat converter changes in 3 years. A garage commented at MOT "petrol leak from fuel injectors which need specialist attention". Is this a tricky job?
Cheers Vince
vincenze is offline Reply With Quote Quote
Old 06-03-2010   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: My first Bravo
Somethings not right if its needed two cat changes. Sounds like its overfuelling horribly.
Is the management light on?
SPD
Old 06-03-2010   #3
Re: My first Bravo
RC, no warning lights on (excpt the airbag warning). But defnitely a fuel issue. Is it a mix or pump issue do you reckon>?
Vince
Old 07-03-2010   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: My first Bravo
Quote Originally Posted by vincenze View Post
Vince
Neither, its probably a sensor or wiring issue.
Have you checked the O2 sensor?
SPD
Old 07-03-2010   #5
Re: My first Bravo
RC, OK that gives me something to work on – you will have guessed that I am an amateur. Should this hook up via the ECU to get a read out?
Vince
Old 07-03-2010   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: My first Bravo
RC, OK that gives me something to work on you will have guessed that I am an amateur. Should this hook up via the ECU to get a read out?
Vince
If you have the right machine with the right software, then yes. Speak to your local autospark who will probably have the equipment to do that.
SPD
Thanks vincenze thanked for this post
Old 07-03-2010   #7
Re: My first Bravo
RC, thank you. Took the car out today, and it's a lovely ride. The judder is so marginal. But yeah that Cat has got to be sorted.
it's true what they say...the ride is very sharp; you feel the road right through your bones.
Always appreciate help from the forum. Cheers Vince
