Hi i have a Fiat Brava & Stilo and could do with some advice on which Diagnostic reader would be most suitable for these both. I've found two but not sure if its ok for both cars. Any help much much appreciated. as this is the first time i've posted i can't post links.
U480 OBD2 EOBD +CAN-BUS Protocol fault Code Scanner/ Reader
U380 OBD 2 II EOBD Fault Code Reader Scanner and Tester
