General novice needs help again..
west lothian
ok to start my temp guage was'nt working and speedo and revs were not showing right speed, so got a second hand dash (£25 scrappies,) fitted it following diagram going about on here (thanks) now the ABS light is on constant, not sure if it has ABS (2001 Y 1.2 16v) if it has could it just be a fault because i changed dash?? brakes work fine..
also airbag light been on since i bought car, to save money is it better to take the bulb out??? cheers for any help..
Personally I would have it code read for the airbag, to see why it is complaining about the A/bag, taking the bulb out will just hide the fact there is a problem, quite dangerious things air bags, last thing you want is for it to go off as you are driving.
My 1.2 1999 bravo has no ABS it is an SX base line model, if yours hasn't then it could be a simple wiring fault.
But get that Airbag checked!
