Technical Headlamp and side strip question.
sakenomido
I had a prang the other day due to the ice, breaks locked (yes I pumped) and I went into the back of a truck, the truck and driver where fine but I smashed the glass for the off side headlamp (the bulbs are still working) can I get a replacement? just the glass.
Also the plastic strip on the side of the car has started to bend away from the car I tried to superglue this but no luck anyone got any ideas to fix this? or do I have to by a new strip?
all the best,
Cheers.
You can get a new side strip, fiat is probably the best bet. Make sure you clean the car door/quater before you stick the new strip on and make sure you hold it on the car tight for over a day.
The standard lights are very cheap and easy to get hold of secondhand. Scrapyard or eBay would be best.
