Thread Tools
Old 15-11-2009   #1
Unhappy brava heater died
wright the heater controls hav died teh dials light up but u can move all dials to any postion and the motor wont come on i hav had all teh fuses out and checked so my next point of call is relays does the diesel 2 litre brava hav a realy for its climate control and if so where is it and is it likely all teh resistor packs hav just suddenly died ? thanx in advance
car is a 2000 plate brava 1.9 JTD ELX
its also for sale by the way message me if interested plz
TURBO
fiat brava jtd elx 105 is offline Reply With Quote Quote
Old 16-11-2009   #2
Re: brava heater died
sounds like weve got the same problem
tobyn123 is offline Reply With Quote Quote
Old 16-11-2009   #3
Quote Originally Posted by tobyn123 View Post
k ill let u know if i sort it then to point u in the right direction
TURBO
Old 16-11-2009   #4
Wink Re: brava heater died
cheers me old mucker
Old 16-11-2009   #5
does everything else work ok on yours m8 ive checked everything and the only thing not working is the fan and heated mirrors but all fuses are intact i dont suppose u happen to know where the relays r on this motor do u m8
TURBO
Old 16-11-2009   #6
dont have heated mirrors on mine, but everything else does, only checked the fuse according the bravo guide site, but yeah everything else is fine, and nah aint got a clue on relay location
Old 17-11-2009   #7
found out today that the cigarette lighter also dead
Old 17-11-2009   #8
Unhappy Re: brava heater died
id check fuses then m8 sounds like its blown if it keeps blowin could b a short
TURBO
Old 19-11-2009   #9
Ireland
there is a connector on the front of the fuse/relay box under the dash, which supplies the fan. one of the pins overheats and burns up causing lack of fan, so pull off the connectors and check each one carefully. disconnect the battery first before going at it.
Faster Horses, Younger Women, Older Whiskey and More Money.
'01 Bravo JTD100, '98 Coupe 20VT
stylers is offline Reply With Quote Quote
Old 19-11-2009   #10
Quote Originally Posted by stylers View Post
sounds like that good well be it, any chance of a picture.....cheeky i know but would be greatly appreciated
*edit*
do you mean front facing into the cab or front facing the front of car
Old 3 Weeks Ago   #11
Greece
I also have a problem with heating.
My car has air conditioning, and the heating does not work.
I adjust the temperature but the air is always cold.
The fan works normally.
NickBr is offline Reply With Quote Quote
Old 3 Weeks Ago   #12
varesecrazy has donated!
Quote Originally Posted by NickBr View Post
Does the temp gauge get to halfway..?
Do the tubes going into cabin get HOT?
varesecrazy is online now Reply With Quote Quote
Old 3 Weeks Ago   #13
Greece
Thanks for the interest.
The car has automatic air conditioning, it is 100 16V ELX, 2000 model, it has temperature selector with AUTO position for the fan.
The temperature indicator is functioning normally always stops in the middle of its motion.
I have not check the tubes, but i will do this tomorrow.
I will also make a preventative vent in the heating circuit to solve the problem, though I do not believe it will do anything, because I have not disturbed the circuit for a long time.
Today I noticed something more. There is a place for dehumidification on the right rotary selector switch named MAX DEF and is not working.
Old 2 Weeks Ago   #14
Hi.
Thats the standard dash.. my mereas had that
You push a button for aircon..
Its NOT CLIMATE CONTROL..
Today .. check the tubes for HEAT..
I still suspect you have a coolant circulation problem (airlock)
Old 1 Week Ago   #15
Greece
It is a climate system .... but 20 years old
For the problem i did check the tubes and these were both hot, i did also a Ventilation of the system.
I touched with my hands the point where the inner radiator was located and it was warm, so the water was circulating.
After this i put out the nnumber 10 in the following diagram:
This spare called electric motor:
Turning the temperature selector from side to side the shaft rotated normally.
But the inside flap was stuck in the cold position.
Using a pinch, I turned it .
After this i put the electric motor on again and at the moment it is working fine.
Also is working and the function MAX DEF, maybe it needs an information from the potensiometer which is inside the electric motor.
Thread Tools
(G) Brava Died ilsonemo Bravo / Brava 4 26-03-2009 14:11
(T) Heater Matrix Died a1ant Bravo 5 07-01-2009 01:17
(G) 1997 Brava 1.6 died and will not restart. VolvoV70T5 Bravo / Brava 6 23-05-2008 11:01
(T) my wifes brava died mrxktm Bravo / Brava 11 30-12-2006 14:01
(T) my brothers brava has died!! robillum Bravo / Brava 1 30-05-2006 11:54
