Hi fiat forum.
I just got my hands on a nice fiat brava 1,6 16V (103Hk)
yesterday i found out that the servo system was leaking and desided to check the car, i found the leak, and its not somthing i can repare, only replace to a new part.
but in order to be able to drive without damaging the pump, i tried to remove the servo rim, but as i was trying to remove the generator rim, i came across the tensioner below the generator, and i just cant se how this tensioner works. i removed the 15mm bolt, and ended up with a big Hex look alike thingie, and a 15mm bolt, and still the tensioner was fixed.
in the end giving up, i just cut the servo rim.
but when i get the new servo hydralic hoses, i need to be able to remove the generator rim.
could someone please be so kind and tell me how to deal with the tensioner below the generator.
Thanks and best regards.
Rasmus Larsen.
Rasmus Larsen.
