Hi All,
Please can anyone help. I have a '97 FIAT Brava 1.4sx
Three days ago, the car was perfectly ok. All I did a couple of days ago was to give it a wash. But I did not drive it at all over after that and for the past two days.
This morning, I tried to start the car, it would crank but it just would not fire up. All the instrument lights come on and go off in the normal way.
I have looked in the engine bay, and nothing was wet or damp. Might be a bit cold this morning, but it has been a lot colder before and the car had no problems.
I have checked all around for loose connections and the fuses, all these seem ok.
I have changed spark plug leads and tried to start again...still the same.
I took out the spark plugs, and they seem to have some oil on the tip. The tip was slightly black which I could clean off. There were also some slight dirt around the top of the thread. Thinking that this might be the problem, I changed all the spark plugs and tried to start the car again, but still no go...still the same.
I checked the oil level (2500 miles since oil change), and it was in between the MAX/MIN mark, so does not look like too much oil.
The car is 80% full of fuel and I believe the fuel pump is working, as you can hear it when you turn the key and the instrument lights first come on.
I am baffled.
I have stopped trying for now, as I feel the battery is probably loosing all it's charge...so charging it back up at the moment.
Seems quite weird that the car was perfectly ok 3 days ago, and suddenly decides to give after two days of standing.
Anyone with any ideas on what might be the problem ? Any help greatly appreciated. Thanks in advance.
I am baffled.
