Hi guys. After some help my clutch pedal is sticking half way up every so often and is using a bit of fluid, i was wondering if it is more likely to be the slave or master cylinder ? Also are all slave and master cylinders the same across all bravo's as i have a 97 hgt, would ones from another model fit, should i just get both from scrapper and change both, cheers
