Technical Need Help How to dismantle my bravo's Rear headlamp.
maltesebravoboy
Fgura
Dear everyone, here in malta we had a terreble rainfall and my rear headlamp the one with the reverse light is floded with water. PLEASE CAN ANYONE HELP ME IN HOW I CAN SOLVE THIS PROBLEM??:slayer:
My Bravo is a 2001 Model
16/16v
Hello welcome to the forum.
You cannot dismantle the rear light cluster. You can only remove it from the car by taking off the boot trim then removing the three 10mm nuts holding the light cluster to the car.
I had the same problem and found it was the foam seal on the back of the light cluster letting water into the car and light. I used silicone sealer arround that foam seal and refitted the light.
Now my lights and boot are dry. You should check your spare wheel well for water.
Hi Adrian,
Thanks for your info so i need to check the spare wheel to see if water had come in.What type of sealer do i need to use??
