E emzo New member Written a guide Joined Nov 1, 2008 Messages 181 Points 42 Location Bulgaria Sep 14, 2009 #1 Will 14" alloys fit on Bravo HGT ? Would brake calipers be a problem or alloys will fit perfect ?
bulldog5046 faster! FASTER!!! Parked in the garage Written a guide Joined May 8, 2005 Messages 9,053 Points 1,538 Sep 14, 2009 #2 no, they wont wont fit over the front calipers, 15" minimum Ry
OP OP E emzo New member Written a guide Joined Nov 1, 2008 Messages 181 Points 42 Location Bulgaria Sep 14, 2009 #3 Actually i'm about to install rear disc brakes in marea 1.6. So front calipers are marea's stock, rear are from 2.4 TD with 240.5x39.7 brake discs. Will this combo fit with 14" alloys ?
bulldog5046 faster! FASTER!!! Parked in the garage Written a guide Joined May 8, 2005 Messages 9,053 Points 1,538 Sep 15, 2009 #4 what size are your front disc's? 284mm? Ry
OP OP E emzo New member Written a guide Joined Nov 1, 2008 Messages 181 Points 42 Location Bulgaria Sep 15, 2009 #5 257mm FRONT 240mm will be REAR disc's
bulldog5046 faster! FASTER!!! Parked in the garage Written a guide Joined May 8, 2005 Messages 9,053 Points 1,538 Sep 15, 2009 #6 a 14" rim would fit then, but personally if i were you i would upgrade the front brakes to 284 and run 15" rim's
