a lot of exhaust gas is blowing from the gasket as seen in the images. If I hold my hand to it, it feels like blowing from a 2-3 cm wide gap. Motor is only a slightly louder, but tends to kill itself sometimes when idling and very rarely studders a bit when accelerating.
How to get it tight again? Is there some special tightening substance, or will it be sufficient to order the original seal from Fiat?
I read about brushing the parts with a steel brush, then fitting the new gasket. The car was already 2 years ago at the mechanics and was tight for about a year and half, now the last months it started to smell of exhaust gases...
However, I've never done it, and the manual does not tell much.
What do I need to do the job? Temperature-resistant cooper paste? New bolts?
I'm thinking of taking only the exhaust manifold of, clean it and the other end of the exhaust pipe to which it connets - is it possible to remove the manifold without getting under the car and without help from a second person (and without the exhaust pipe falling of)? How to fit the new gasket, does one have to glue it?
Thanks,
Zardo
Thanks,
Zardo
