chris hgt 147
anybody know if you can get 50mm lowering springs for this car and what make of spring i cannot find them anywhere cheers chris
Well the other day i was lucky enough to walk into my local car breakers and find two bravos. Immediately i searched both car thouroughly for mods and found that one of them had 50mm eibach lowering springs all round. But not only springs. It also had lowering shocks too! Grabbed all shocks and springs for 50 quid. Just gotta look around buddy. How much you looking too pay?
about 100 quid mate are you willing to sell them if you know what bravo they came off because the shockers will not the hgt model the springs will tho cheers mate chris
I don't want to sound like a kill joy, but Eibach never made a 50mm lowering spring or kit for the Bravo I. I have Eibach's and the most they lower is by 30mm. There is no shortened shocks either made by Eibach for the Fiat Bravo I.
So i've no idea what springs or shocks you've bought. Also if you dont believe me ring Eibach.
lol. I did ring eibach to buy new ones from them. And then rang them back too check that the ones i found are genuine. Eibach do 50mm and another company does 60mm.
Actually sold Pro-Kit is for 1.4 1.6 and 1.8 Bravos, 2.0 HGT is no more included in Eibach catalog.But on the off chance Eibach made a set im sure you can read off the Eibach code on the springs, like you did to confirm they are genuine. Or show us a link on any car site on the net that sell Eibach 50mm Bravo lowering springs or Eibach Suspension kits that lower 50mm.
Eibach only does the Pro-Kit for the Bravo (182), the max they lower is 30mm.
I have a MKI HGT (147hp) with Eibach springs and custom (racing-like) shock abs.
I will NOT tell you how much the car is lower from stock...
Just look at this: My Garage
Sorry, I don't believe you. But dont take it the wrong way, I have been known to be wrong in some cases, but I have been on the phone to atleast 10-15 auto stores in regards to Eibach springs for my car including Eibach.co.uk themselves and none lower the car more than 30mm.
alls i want to know is there a spring set out to buy that can lower a hgt to 50mm thanks chris
-Ride height is done by spring stiffness and lenght, NOT from shock abs! Shock Absorbers function is to BRAKE the spring inertia, that could cause the car bouncing after hitting a road imperfection. Modern shocks have also some "lifting" strenght, but not so much... 30mm of EXTRA lowering from shocks is totally impossible, maybe 5mm...Shorten Shocks lower ride height more when matched with lowering springs, typically an extra 10-30mm depending on springs and shocks. So add the Eibach lowering springs and you'll be looking at a drop of around 50mm.
Also why does your garage page say that they are Eibach Sportlines? No Sportlines available for any Bravo (182). Also fitted by previous owner.
