In the past few weeks the volume control in my Brava stereo has started to become erratic. It does the following when you move it.
You turn the volume down, but it will go up (sometimes in massive jumps, such as 10 to 21. makes you jump as well.)
Sometimes it just move one notch, however many times you turn it. e.g 14 then 15, then 14, then 15.
As you can imagine this is very annoying as you have adjust it very very very gently one notch at a time (thus trying to concentrate on the road as well) or in most cases stop & pull over to do it.
It appears the switch has become too sensitive, so is it a case of replacing the stereo??
It is the original stereo with the sony CD changer hooked up to it.
