Old 18-01-2009   #1
Question Spec for Front shock absorbers
Hi, I've got to replace the front dampers on my '98 bravo 1.6.
first, does anyoe know which are best: Magneti Marelli ones or someone mentioned KYB Excel-G in another thread. The Magneti Marelli ones are almost twice the price but are OEM spec, do the KYB ones stand up to them?
Secondly, does anyone know whether adding bump stops would be benificial and what size bore would I need?
Chars
Rob666 is offline Reply With Quote Quote
Old 18-01-2009   #2
bpetersb has donated!
Re: Spec for Front shock absorbers
KYB are fine, another make often available from motor factors, probably better known, is Munro. All the decent aftermarket makes will be engineered to give the same or very similar performance as the OEM (with regards to compression damping and rebound) for standard fitments.
bpetersb is offline Reply With Quote Quote
Old 18-01-2009   #3
cool, cheers for that.
(G) Shock Absorbers T-Jet 120 Marea 23 01-10-2012 16:42
(T) Replacing the front shock absorbers for a '99 Seicento Abarth. tnt Cinquecento / Seicento 14 19-01-2009 01:26
(T) Shock Absorbers sjladopoulos Barchetta 41 11-01-2008 09:17
(G) Changing front shock absorbers question markos2 Punto (Mk2/2b) 3 14-06-2007 20:34
