the bloke came out with the diagnostics gear and tried to do a diagnostics but the bravo wouldnt let him into the ecu..so basically we didnt find out what it was. he says that i should disconnect the negative of the battery then disconnect the ecu for a few hours. then reconnect the ecu then the negative to the battery. then put key in and turn the key but not start the car. leave it for 30 seconds or so then take the key out and put it back in and turn the ignition on for about another 30 seconds to see if the ecu will reset itself and hopefully start. if it doesnt start then he seems to think that it will be the ignition module at fault. does anybody agree. also should he have charged me the £40 i paid him for the diagnostics that he couldnt do. im a bit bemused.
