Hi to all fiat fans,ive got an 96 1.4s bravo,its been brilliant for ages but lately its been hard to start from warmed up.The problems got worse since last week when i put a new thermostat in it,europarts item,ive noticed that the ignition coil gets very hot so i tried to move it away from block.It stays cool now but problem persists!:bang:If it wont start a fiddle with the electrical connector 5 or 6 times putting on and off usually gets it going,is it the coil breaking down as when its cold it starts fine??i changed the therm as the old one was stuck open which made injector light occasionally come on plus heater didnt heat up,this solved the igniter prob! sorry to be long winded but thought it best to explain fully-hope one of you out there can point me in the right direction.Thanks for your time!!!!
