Greame Smithy
- Oct 26, 2008
- 5
- 2
Hello Folks,
I've been checking the forums to seek an answer to a certain problem, namely my engine temp takes a good 15 minutes to come to mid way on the gauge and if the weather is cooler than say 10 degrees and I'm travelling at speed the engine temp drops, (it has gone so low as to make the engine management light to come on)...It would seem like the Thermostat is stuck / sticking open. To that end I intend to replace the thing.
The car, a Brava X reg ELX 1.6 has a ridiculously placed stat and housing and whilst I'm not a total wazzock knowing which end of a Hammer to hit the thing with any guidance regarding possible pitfalls will be appreciated.
I'm thinking...Nice warm day, (cold spell should clear by next weekend!), Battery tray out, remove old stat/housing, screw temp sensor in new thermostat, replace with new stat and housing, drain coolant, replace with fresh... Bingo.
What size Jubilee clips for re fixing pipe work? Any sealant required before fixing pipes? Will it be simpler to garage it in the Kingston on Thames area?
Many thanks
Greame:slayer:
Many thanks
Greame:slayer:
