can anyone tell me in detail on how to time a fiat brava 1.2 16v please
tryed that but it made the car seep fuel and air mix out of the air filter
so does that mean we have to turn the crank around 360 or just 180? Because we tried orginally 360 and it didn't make a difference
my mate went down fiat today and asked about the timing tools for me, they told him for that cam locking tool and the piston tool think it will take about 2 month to come through
if removing the lead with engine running makes no difference on that clyinder, and you know that the plug and lead are definately fine and sparkign, then the only possible problems are a head gasket leak on that cylinder (common on a 1.2) or an injector fault on that cylinder (very rare on the 1.2).
no, if the ecu detects any fault at all it illuminates the light.if the timing was out dont you think that injecter light would of gone out
tbh that is what i do too, but its very dangerous so i have never once mentioned it on the forum. if the spray catches your skin then you only have a short while to live. its a simple and useful test, but please do it carefully.arc said:took the fuel rail and injectors off and fired them into the air.
