westystella
- Aug 31, 2006
- 43
- 25
my new car has got spotlights on it, but im wondering is legal 2 drive round with them on???
Requirements about the use of headlamps and front fog lamps
25.—(1) Save as provided in paragraph (2), no person shall use, or cause or permit to be used, on a road a vehicle which is fitted with obligatory dipped-beam headlamps unless every such lamp is kept lit-
(a) during the hours of darkness, except on a road which is a restricted road for the purposes of section 81 of the Road Traffic Regulation Act 1984 by virtue of a system of street lighting when it is lit; and
(b) in seriously reduced visibility.
(2) The provisions of paragraph (1) do not apply-
(a) in the case of a motor vehicle fitted with one obligatory dipped-beam headlamp or a solo motor bicycle or motor bicycle combination fitted with a pair of obligatory dipped-beam headlamps, if a main-beam headlamp or a front fog lamp is kept lit;
(b) in the case of a motor vehicle, other than a solo motor bicycle or motor bicycle combination, fitted with a pair of obligatory dipped-beam headlamps, if-
(i) a pair of main-beam headlamps is kept lit; or
(ii) in seriously reduced visibility, a pair of front fog lamps which is so fitted that the outermost part of the illuminated area of each lamp in the pair is not more than 400 mm from the outer edge of the vehicle is kept lit;
(c) to a vehicle being drawn by another vehicle;
(d) to a vehicle while being used to propel a snow plough; or
(e) to a vehicle which is parked.
(3) For the purposes of this regulation a headlamp shall not be regarded as lit if its intensity is reduced by a dim-dip device.
I
2 Front fog lamp Manner of use prohibited
(a) Used so as to cause undue dazzle or discomfort to other persons using the road.
(b) Used so as to be lit at any time other than in conditions of seriously reduced visibility.
(c) Used so as to be lit when a vehicle is parked.
and if your referring to Driving lights they should only come on when the main beam is used...
to tell other boyracers that you have points to spare on your license and you are in racer mode.Why do people drive with these on,
in the uk spot lights, driving lights and fog lights are all classed as the same thing by the police. i've tried that excuse more than once. it doesnt work, even if your owner manual says they are driving lamps to aid your visibility to other drivers. end of the day uk road law applies in the uk, nothing else matters.
The new Audi's have LED driving lights, not illegal to drive with them on all day. But then again i maybe getting confused with daytime running lights.
legally DRLs are class as sidelights in the uk.The new Audi's have LED driving lights
Slight change of subject here, but since the new Audis have almost a headlamp almost entirely made up of LEDs (DRL, Sidelights & Indicators), does that mean aftermarket white LED sidelights can now become legal or what?
Wrong, they come on when.......driving. Usually a daytime driving light. Hence the name.
Yes, 99.9% are fog lights.most are surely front fogs, the symbol on the dash display being that of a rear fog, only pointing downwards, thus front fog. Not only this but driving lights tend to be mounted higher, where fogs are mounted low in the bumper.
