Barrow Bravo
- Oct 7, 2008
- 3
- 1
Hello All,
Problem with clutch on my 1996 Bravo 1.8 HLX.
When the engine is running and I dip the clutch to select a gear, the gear stick is just solid and wont select anything.
When the engine is off, i can select a gear fine but when i start the car with the clutch pedal down, then it stalls cos the gear is engaged, even with the peddle down!!
Theres no visible leaks and the fluid level is fine.
Any ideas please anyone.
